| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.XXX |
| Environment: | Windows 7 64 bit & Others |
| Area: | Processing |
| Subarea: | |
| Original Author: | Kestutis Mitkus, Bentley Product Advantage Group |
How to skip THREAD Weld IDs in AutoPLANT Modeler’s isometrics that are generated via OpenPlant Isometrics Manager.
communities.bentley.com/.../12647.modifying-symbols
communities.bentley.com/.../12829.modifying-rectangular-enclosureboundary-in-open-plant-isometric-annotations
communities.bentley.com/.../17960.how-to-get-autoplant-weld-ids-in-opim
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
