| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.458 |
| Environment: | Windows 7 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | |
| Original Author: | Abhijit Bute, Bentley Product Advantage Group |
While generating isometrics in DWG format, sometimes user may face problem of mating flange rotation in wrong direction. Following steps would help user to get the correct flange orientation.
Close seed file and regenerate isometric it to verify results. It should produce correct rotation in drawing.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
