| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.417 & above |
| Environment: | Windows 7 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | |
| Original Author: | Rahul Kumar, Bentley Technical Support Group |
In OpenPlant Isometrics Manager, below exercise illustrate on mapping PDW to OpenPlant Isometrics manager classes. It can be realized with AutoPLANT Modeler.
With AutoPLANT Modeler version SS5 and SS6 release uses OpenPlant Isometrics manager to generate Isometrics. There are certain classes from AutoPLANT that have not yet been mapped in OpenPlant isometrics manager. This document will describe the process of mapping an instrument gauge class but can be used for any classes which may need mapping. Below exercise will search the database for instrument classes used and map an instrument gauge class. No instrument classes are currently mapped in OpenPlant Isometrics Manager.
B. Mapping the class in the schema
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
