| Area: | Drawing Views | ||
| Subarea: | Output |
Linework is missing on walls and Fill is sporadic in the Dynamic Drawing View, but when the model is Cached, they display correctly..
The 3D model was found to have an extended very long Free Form leading into the model, which when deleted solved the issue. Then the drawing model displayed the same in Dynamic or Cached views.
