| Area: | General | ||
| Subarea: | Installation | ||
After installing AECOsim Building Designer CONNECT Edition, the user wants to again install Generative Components separately.
Go to Control Panel - Select AECOsim Building Designer CONNECT Edition.
Click on Modify - AECOsim CONNECT edition installer opens.
Tick on Generative Components box - Click on Modify - Generative Components starts downloading automatically.
Select Finish to end installation.
Again open CONNECT Edition installer to confirm if it is installed.
