| Product(s): | Bentley speedikon Architectural + Industrial | ||
| Version(s): | 08.11.12.09 | ||
| Area: | General | ||
| Subarea: | N\A | ||
| Original Author: | Johannes Lerch, Bentley Technical Support Group | ||
The following document compares the functionality of Bentley speedikon Industrial with Bentley speedikon Architectural V8i (SELECTseries 5) in a detailed table. Bentley speedikon CONNECT Edition includes the full speedikon Industrial functionality.
Since speedikon V8i (SELECTseries 5) the following modules are part of Bentley speedikon Architectural:
• 3D-Construction
• QuantityTakeoff
• AttributeFilter
Since speedikon V8i (SELECTseries 5) the following module is part of Bentley speedikon Architectural and Bentley speedikon Industrial:
• ProjectEditor
Functionality |
Bentley speedikon Industrial V8i (SELECTseries 5) |
Bentley speedikon Architectural V8i (SELECTseries 5) |
Managing Project Data |
Project and site information |
Yes |
Yes |
Repositories are located in ProjectWise database or in a file system workspace |
Yes |
Yes |
Navigating by ProjectWise Explorer or built-in Project Manager |
Yes |
Yes |
Easy access to non-graphical building model data with Project Editor utility |
Yes |
Yes |
Project and model file archives including SMD utilities |
Yes |
Yes |
Modeling |
Geometric data input and storage with engineering precision |
Yes |
Yes |
Building coordinate system aligned to geo coordinates |
Yes |
Yes |
Grid types (column grid, ceiling grid) |
Yes |
Yes |
Reference planes for easy elevation changes |
Yes |
Yes |
Architectural space concept (data, space boundaries, relationships) |
Yes |
Yes |
Walls (single, layered, tilted, curtain, custom) |
Yes |
Yes |
Windows, doors (by cell or scripted) |
Yes |
Yes |
Industrial sectional doors, rolling shutters, rolling grilles |
Yes |
No |
Floors, ceilings |
Yes |
Yes |
Ramps, stairs, handrails |
Yes |
Yes |
Platform stairs (straight, L-shaped, U-shaped) |
Yes |
No |
Railing systems for platforms |
Yes |
No |
Caged ladders |
Yes |
No |
Gratings (standard and heavy duty) |
Yes |
No |
Roofs (simple or scripted) |
Yes |
Yes |
Skylights for smoke and heat extraction/exhaust systems |
Yes |
No |
Model elements for several usage (by cell, form modelled, scripted, constrained) |
Yes |
Yes |
Slabs, beams, columns |
Yes |
Yes |
Framing details (braces, haunches) |
Yes |
No |
Connection details (base and end plates, gusset plates) |
Yes |
No |
Truss builder |
Yes |
No |
Plate girders |
Yes |
No |
Cross steel section columns |
Yes |
No |
Space boundaries and containment |
Yes |
Yes |
Automatic wall alignment to floor slabs and roof sections |
Yes |
Yes |
Automatic column alignment to beams and slabs |
Yes |
Yes |
Automatic opening creation if columns penetrate suspended ceilings |
Yes |
Yes |
Important design properties: material, fire rating, thermal resistance, space temperature, sound reduction |
Yes |
Yes |
Custom properties by attaching user defined attributes |
Yes |
Yes |
Model complies with data requirements for clash detection |
Yes |
Yes |
Tagging |
Model elements tagging controlled by attribute filters |
Yes |
Yes |
Reporting |
Space reporting |
Yes |
Yes |
Quantity take-off |
Yes |
Yes |
Business data reports |
Yes |
Yes |
Publishing |
Building models in IFC file format |
Yes |
Yes |
Building models in PDF file format |
Yes |
Yes |
Drawings in DGN file format |
Yes |
Yes |
Drawings in native DWG, DXF file format |
Yes |
Yes |
Building Annotation |
Dimensioning tool set |
Yes |
Yes |
Model element associative labeling |
Yes |
Yes |
Section markers |
Yes |
Yes |
Exterior and interior elevation markers |
Yes |
Yes |
Graphical symbols for safety signs according to ISO 7010 |
Yes |
No |
Drawing Production |
Drawing composition |
Yes |
Yes |
Templates for ISO standard sheet sizes and non-standard sizes |
Yes |
Yes |
Customizable title blocks |
Yes |
Yes |
Floor plans, sections and elevations from model |
Yes |
Yes |
Drawing generation controlled by display filters |
Yes |
Yes |
Updating drawings by scheduled batch jobs |
Yes |
Yes |
Drawing revisions |
Yes |
Yes |
Plot files in PDF file format |
Yes |
Yes |
Interfaces |
IFC export for design coordination |
Yes |
Yes |
GBXML export for energy analysis |
Yes |
Yes |
DGN import and export for slab, beam, wall perforators |
Yes |
Yes |
STAAD export and import for steel structure analysis |
Yes |
No |
SDNF export and import for steel structure detailing |
Yes |
No |
Programming |
API for VBA |
Yes |
Yes |
Macro scripting language |
Yes |
Yes |
The same document in German language:
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0107795
