| Product(s): | OpenPlant Isometrics Manager & AutoPlant Modeler |
| Version(s): | 08.11.09.458 & 08.11.11.135 |
| Environment: | Windows 7 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | |
| Original Author: | Abhijit Bute, Bentley Product Advantage Group |
Using AutoPLANT Modeler & OpenPlant Isometrics Manager user is getting error as "Scaler, Symbols or item codes are missing for TAP_CONNECTION" while generating isometrics as shown below.
Scaler, Symbols or Item code are missing for TAP_CONNECTION error message when branch connected through Stub-In tap port.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
