| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | |
| Original Author: | Abhijit Bute, Bentley Product Advantage Group |
When Coordinate unit set to INCH in Isometric configuration and place any Miscellaneous Attachment on pipe isometric crash with following error.
Below are the steps to fix this issue.
