| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.404 & above |
| Environment: | Windows 7 64 bit |
| Area: | Settings/Attributes |
| Subarea: | - |
| Original Author: | Abhijit Bute, Bentley Technical Support Group |
Sometimes user required DWG isometric component with specific color and line style, line weight. So that it will match with their predefined plot style, and generate isometric with their own standard.
Below steps help you to convert OpenPlant Isometrics Manager isometric DGN to DWG with as per required color.
For more details please refer below link.
http://communities.bentley.com/products/microstation/w/microstation__wiki/the-power-of-csv
http://communities.bentley.com/communities/other_communities/askinga/w/askinga/microstation-s-element-types
communities.bentley.com/.../12636.setting-file-type-dgn-or-dwg-and-paper-setting
