| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | DBQuery |
| Original Author: | Abhijit Bute, Bentley Product Advantage Group |
In general, the majority of data for Isometric output is gathered from the Piping table. However, situations can arise where data from other tables in the Project Database could be valuable for placement on Iso's. The following illustrated steps demonstrate how to pull a field from the Process table into Isometric backing sheet.
Adding Configuration Files
In workspace for isometrics does not include the query and grid functionality. It can be added by adding 2 configuration files. Copy attached gridlines.txt and textnodes.txt and paste it in style configuration directory. Ex. \Bentley\Plant V8i\Bentley PlantV8i Projects\SAMPLE_IMPERIAL\Config\OpenPlant\Isometrics\Styles\IFC\ Config
Please find the query file below to be pasted in style configuration directory:
communities.bentley.com/.../Gridlines-_2600_-Textnodes-File.zip
Create New Drawing Attribute & Define Query
To get database attribute in Drawing Tag dialog ,user need to add query, project database location in textnodes.txt file,While creating an isometric AP adds a few standard drawing attributes. Currently these are:
FILENAME ISO-L1000.r017
STYLE IFC
DATE 3-3-2014
TIME 11:45:28
PRJ_NAME ROTAT1
SIZE1 150
SIZE2 0
SPECMAIN MCS150
LINENUMBER L1000
UNIT U
SERVICE S
NAME ISO-L1000
ALIAS ISO-L1000
ACTIVE True
Marked LINENUMBER in upper case, as this attribute will be used in the examples to query the database.
A For MS Access (32bit) Following Query should be added in Textnodes.txt
mydsn=Driver={Microsoft Access Driver (*.mdb, *.accdb)};Dbq= C:\ProgramData\Bentley\Plant V8i\Bentley Plant V8i Projects\SAMPLE_METRIC\Projdata\projdata.mdb;
00_keytag = DBQUERY ($(mydsn), select keytag from TAG_REG where tag_no='$(LINENUMBER)')
Note: The above project path shown is an example. User need to set their own path as per their project.
The DBQUERY above gets the value of the KEYTAG column in the TAG_REG table from the row where the TAG_NO column equals the value contained in LINENUMBER drawing attribute. The resulting value is stored in a new drawing attribute named 00_KEYTAG.
Please note that $(attrname) is expanded to the value of the drawing attribute attrname. LINENUMBER is a drawing attribute that was already added by the AP interface to OPIM
Similarly we can define query for other attributes like popp_nom, popt_nom, FLUID_FILL as described below.
00_popp_nom = DBQUERY($(mydsn), select popp_nom from process where keytag='$(00_keytag)')
00_popt_nom = DBQUERY($(mydsn), select popt_nom from process where keytag='$(00_keytag)')
00_FLUID_FILL = DBQUERY($(mydsn), select FLUID_FILLING_FACTOR from process where keytag= '$ 00_keytag)')
Refer below image for edit textnodes.txt file.
B For MS Access (64bit) Following Query should be added in Textnodes.txt
mydsn=Driver={Microsoft Access Driver (*.mdb)};Dbq=C:\ProgramData\Bentley\Plant V8i\Bentley Plant V8i Projects\SAMPLE_METRIC\Projdata\projdata.mdb;
00_FLUID_FILL = DBQUERY($(mydsn), select FLUID_FILLING_FACTOR from process where keytag='$ (00_keytag)')
C For SQL database following query should be added in textnodes.txt
mydsn=Driver={SQL Server};Server=SQL Server name;Database=sql databse name;
Uid=user id;Pwd=password;
The isometric result can be viewed using the Show Tag Data tool (first 4 lines)
Display Drawing Attributes
Below are the steps to get the attributes displayed in backing sheet.
36, checked
63,UNIT_NAME
64,STYLE
1001,00_KEYTAG
1002,00_POPP_NOM
communities.bentley.com/.../18475.dbquery-usage-logging-debugging
communities.bentley.com/.../17953.db-query-for-multimode-project-environment
