| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | DBQuery |
| Original Author: | Abhijit Bute, Bentley Product Advantage Group |
Some user requirement to place external database file on server and all users can access that files. For fetching data from external database to Isometric backing sheet, need to mention full database path in textnodes.txt file. Following steps will aid user to create db query for Multimode project environment.
Write below query in textnodes.txt file.
mydsn=Driver={SQL Server};Server=BUTEA7453PUNL;Database=Bentley;Uid=sa;Pwd=Bentley123;
projid = DBQUERY ($(mydsn), select PROJ_ID from PROJECT where DESCRIPT='$(PRJ_NAME)'and ITEM='ProjectName')
00_keytag = DBQUERY ($(mydsn), select keytag from TAG_REG where tag_no='$(LINENUMBER)'and proj_ID='$(projid)')
00_popp_nom = DBQUERY($(mydsn), select popp_nom from process where keytag='$(00_keytag)' and proj_ID='$(projid)')
00_popt_nom = DBQUERY($(mydsn), select popt_nom from process where keytag='$(00_keytag)' and proj_ID='$(projid)')
00_ppaint = DBQUERY($(mydsn), select DISTINCT ppaint from process where keytag='$(00_keytag)'and proj_ID='$(projid)')
If there is still some problem, then please create a Service Request and contact Bentley Product Advantage group along with the list of all relevant details to get in depth analysis and for possible solution or workarounds.
communities.bentley.com/.../18475.dbquery-usage-logging-debugging
