| Product(s): | Bentley speedikon Industrial | ||
| Version(s): | 08.11.12.XX | ||
| Environment: | Windows 7 64 bit | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Carsten Gauger, Bentley Technical Support Group | ||
You can choose between two different speedikon BIM products in speedikon V8i:
Note: Speedikon CONNECT Edition contains the entire Speedikon Industrial functionality!
The entire functionality of Bentley speedikon Architectural is part of Bentley speedikon Industrial.
Bentley speedikon Industrial contains the following additional features:
Structural steel design
Platform design
Additional opening elements
A more detailed functionality comparison between speedikon Architectural and Industrial:
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0100764
http://www.bentley.com/en-US/Products/Bentley+speedikon+Architectural/
