| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | Isometrics Generation |
| Original Author: | Abhijit Bute, Bentley Product Advantage Group |
In OpenPlant Isometrics Manager, during isometrics generation it displays error as Element ‘VALVE_HAS_VALVE_OPERATING _DEVICE’ is missing required attribute ‘sourceClass’
Problem arise when we place instrument(Flow Meter) and valve operator(Hand Wheel) on it. Instrument not accepted as source for the ‘VALVE_HAS_VALVE_OPERATING _DEVICE’ relationship.
Below steps will aid user to avoid such errors. Below example and error caused shown here using AutoPLANT Modeler and OpenPlant Isometrics Manager.
Open Bentley Class Editor.
Open "OpenPlant_3D.01.04 schema". See Image below.
Note - Path to check - (C:\ProgramData\Bentley\Plant V8i\Bentley Plant V8i Projects\SAMPLE_METRIC\Config\OpenPlant\schemas)
Right click on "OpenPlant_3D.01.04 schema" &S click on supplement Schema option.
Using "Add" button, select Supplemental schema "OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.04 schema" and click on "Open". See image below.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
