| Product(s): | OpenBuildings Designer and AECOsim Building Designer | ||
| Version(s): | CONNECT Edition and V8i | ||
| Area: | Import/Export | ||
| Subarea: | Clash Detection |
We are using the Clash Detection tool in OpenBuildings Designer and would like to export a clash detection report similar to a DataGroup schedule. Is this possible? If so, is it also possible to include a 3D isometric view showing each clash?
Yes, you can use the Results > Export All option to output the current clash results list to Excel as shown below:
While there is no facility to include a graphic representation while using this process, you could walk through the clashes and capture the zoomed/color-coded results as individual image files, and then paste them into the appropriate locations in the Excel spreadsheet.
