Using Bentley Facilities Planner's Move Assets and LabelsĀ tool, you can move assets and containers and labels graphically within the model.
To move assets graphically, using the Move tool
- From the Planner menu, choose Tools > Move Assets And Labels.
The Move Assets and Labels window opens, instructing you to use the MicroStation tool of your choose to select and move assets and labels.
- When you finish moving the selected objects, click OK in the Move Assets and Labels window.
