| Version(s): | 08.11.09.404 & above |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Component |
| Subarea: | Graphics |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
Placement of Note type, Isometric Break point on mating flange assembly is the requirement from user. As shown in image below:
Sometimes it often shows a message ‘Select valid Piping Component’ and not allow user to place notes correctly. See image below. Below steps explains on placing the note type correctly.
