| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | till 08.11.11.294 (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | Isometric Configuration |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
In Latest OpenPlant Isometrics Manager version this issue is already fixed
In OpenPlant Isometrics Manager, during isometrics generation it displays error as ERROR[5]: DWG creation failed.
In OpenPlant Isometrics Manager, when “Isometric Output Format” option selected as DWG like shown in below image.
When user generates an isometrics then following error prompts as shown below.
Error:ERROR[5]: DWG creation failed
at Bentley.Isometrics.IsoExtWrapper.GenerateIsometrics.Execute()
at Bentley.Isometrics.IsoProduction.PipeGenerateIso.Process(IsometricInstance isoInst)
at Bentley.Isometrics.IsoProduction.ProcessingPipes.ProcessIsoInstance(BackgroundWorker bWorker, IsometricInstance isoInst, Boolean& success)
Below steps will aid user to avoid such errors. Below example and error caused shown here using OpenPlant Modeler and OpenPlant Isometrics Manager. However similar instances might occur using AutoPLANT modeler and OpenPlant Isometrics Manager.
Case1
Case2
In some cases OpenPlant Isometrics Manager not installed properly or by mistake some files get deleted from following location.
C:\Program Files (x86)\Common Files\Bentley Shared\RealDWG2016
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
