| Version(s): | 08.11.09.404 (SS5) & Above |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Drawing Generation - OpenPlant Modeler |
| Subarea: | |
| Original Author: | Swapnil Joshi, Bentley Product Advantage Group |
How to create a 3D PDF using OpenPlant Modeler
The user might want to review the model in a PDF mode. OpenPlant Modeler does allow us to create a 3D PDF model. Below mentioned steps give us the procedure to create a 3D PDF.
