| Version(s): | V8i | ||
| Area: | Modify | ||
| Subarea: | N\A |
If I mirror a slab and then drag any of its edit handles, the next time I need to modify that slab the edit handles no longer display.
Use the keyin TFREBUILD on the slab in order to re-display its edit handles. If for any reason you need to mirror the slab a second time, simply use the TFREBUILD command again and the edit handles will be retained.
Note: While this issue is reproducible in AECOsim Building Designer V8i SELECTseries6, the edit handles no longer disappear when mirroring a slab in OpenBuildings Designer CONNECT Edition.
