| | Product(s): | AECOsim Building Designer | |
| | Version(s): | CONNECT Edition | |
| | Environment: | N\A | |
| | Area: | General | |
| | Subarea: | Errors | |
Getting random crashes while working in a drawing.
If you are seeing random crashes while working in a drawing, try the following:
- Compress the file.
- Fit a view.
- Place Fence (By View in Overlap mode) in that view.
- Key-in Fence File= in the Key-in Browser and provide an output filename and click OK.
- Accept the Fence Contents in the view - In the prompt field you'll see that the file has been saved.
- Open the new file and see if the crashes continue.
