| Area: | Datasets and Content | ||
| Subarea: | Configuration |
In the configuration scenario where an organization takes ownership of a regional dataset and locates it in a Custom Configuration alongside the Organization and WorkSpaces folders, a small configuration change is required.
The path to the Dataset root folder in a Custom Configuration is set as follows (using W:/OBD/Configuration/ as an example location):
Update 6 and Earlier
On the C:\ drive set the location of a Custom Configuration in the ConfigurationSetup.cfg file, [General] section
_USTN_CUSTOM_CONFIGURATION = W:/OBD/Configuration/
This will result in _USTN_CONFIGURATION being resolved to W:/OBD/Configuration/
In the root of the Custom Configuration, in this example: W:/OBD/Configuration/, modify WorkSpaceSetup.cfg (this can either be a copy of our delivered file, or simply a new file with that name containing only the required statements).
Unless other statements are appropriate in this file, all that is needed are these two lines:
%undef _TF_WORKSPACEROOT
_TF_WORKSPACEROOT = $(_USTN_CONFIGURATION)
The first line clears the existing definition of _TF_WORKSPACEROOT, the second applies the required definition.
Without the %undef statement the application will always use the delivered datasets.
Notes:
Update 7 and later
In Update 7 this behaviour is reversed:
Use datasets in Custom Configuration:
Simply defining a Custom Configuration location will make OBD look for the Dataset root in the Custom Configuration (and to be clear, this only applies when a Custom Configuration is defined). In that use case existing instances of the statements described above can be omitted from WorkSpaceSetup.cfg.
To use delivered datasets on C:\ drive:
If you have a Custom Configuration that does not include a Datasets folder OpenBuildings Designer Update 7 will not find the Datasets folder on the C:\ drive without this small configuration change.
To use the delivered Datasets on the C:\ drive; the statements in the WorkSpaceSetup.cfg at the root of the Custom Configuration will need to be as shown in red below:
# Support for ProStructures Application Integration
# Update 7 and later to use delivered datasets
_TF_WORKSPACEROOT : $(_USTN_INSTALLED_CONFIGURATION)
TF_DATASETS : $(_TF_WORKSPACEROOT)Datasets/
TFDIR : $(TF_DATASETS)$(TF_DATASETNAME)/
This includes the default statements needed to enable integration with standalone ProStructures applications.
