| Product(s): | Bentley Data Manager |
| Version(s): | 08.11.09.140 |
| Environment: | N/A |
| Area: | Database |
| Subarea: | |
| Original Author: | Justinas Lipnickas, Bentley Product Advantage Group |
After changing the database structure for a project, which uses MS SQL as a database provider, changes are not visible within the Data Manager. Please see the steps required to add the
Open DataManager, log into the project;
In the top menu go to Tools->Database Tools...
Select the "Check and Update Link Tables" option, click OK;
After the operation finishes, restart the Data Manager to see the DB structure changes in Data Manager as well.
