| Product(s): | iModel Plugin for Revit | ||
| Area: | Interoperability | ||
| Subarea: | Revit |
The iModel Plugin for Revit is no longer available for download.
The new workflow involves uploading Rvt files to the Bentley Infrastructure Cloud and then syncing them to an iModel.
You will find a detailed description in the new knowledge base article How to import RVT file from Revit into OpenBuildings Designer?
