| Product(s): | AutoPLANT | ||
| Version(s): | V8i, XM, 2004 | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Joey Bertone, Bentley Technical Support Group |
When opening an AutoPLANT model or when specifically activating component preferences, the command line will displaying following unknown commands:
Command: Loading the AutoPLANT Component Preferences. Please wait...
Unknown command "AT_DOCK_CONTAINERV8I". Press F1 for help.
Unknown command "APPREFSELECTAN16.COMPONENTPREFERENCES". Press F1 for help.
The account.arx file has become unregister with AutoCAD for component preference to load the account.arx file must be reloaded.
To correct the component preferences issue use the following steps:
If loading the Account.arx file does not correct the error try registering the file APPERFSLECT17.ocx. Register the file by using the following command in Run.
Go to Start > Run and enter: Regsvr32 "C:\PROGRAM FILES\COMMON FILES\BENTLEY SHARED\PLANT V8i\APPREFSELECT17.OCX"
For other versions of AutoPLANT use the account.arx and apprefselect.ocx can be in the following folders.
C:\Program Files\Common Files\Bentley Shared\Plant V8i
C:\Program Files\Common Files\Bentley Shared\Plant XM
C:\Program Files\Common Files\Bentley Shared\Plant 2004
Understanding Component Preferences In AutoPLANT
Component Preferences Dialogbox Does Not Appear On Screen After Load
