| Version(s): | 08.11.09.593 | ||
| Area: | Modeling | ||
| Subarea: | Compound Cell | ||
| Original Author: | Gerard Torres, Bentley Technical Support Group | ||
I would like to Create a Door without a frame in Parametric Frame Builder.
It is possible in the Parametric Frame builder to create a door witrhout a frame, see the example below:
