| Version(s): | 08.11.09.593 | ||
| Area: | Drawing Views | ||
| Subarea: | Drawing Seeds | ||
| Original Author: | Gerard Torres, Bentley Technical Support Group | ||
What is the default location of the Drawing "Seed" files?
The default location for the seeds files are under:
C:\ProgramData\Bentley\AECOsimBuildingDesigner V8i
Ss4\WorkSpace\BuildingDatasets\Dataset_US\dgnlib
The variable that points to the seeds location is MS_DRAWINGSEED_LIBLIST.
