| Applies to | |
| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64-bit) |
| Area | Errors, Logs, Messages, Crashes |
| Subarea | |
| Original Author | Swapnil Joshi, Bentley Product Advantage Group= |
The schemas do not have mapping of AutoPLANT Class AT_LUG_W_BOLT with OpenPLANT Piping Fastener Bolt Wafer Class. Hence we cannot generate the isometric of the model and get following error.
If the above problem still persist, then please create a Service Request and contact the Bentley Product Advantage Group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
Bentley's Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this Comments and Corrections?" section. THANK YOU!
