| Product(s): | Bentley Facilities | ||
| Version(s): | 10.00.00.45 | ||
| Area: | General | ||
| Subarea: |
Bentley Facilities Planner CONNECT Edition and Bentley Facilities Manager CONNECT Edition are now fully 64 bit binaries. This means that all customizations done using the V8i versions of these application will need to be compiled as 64 bit binaries. Bentley Facilities SDK CONNECT Edition provides an SDK for re-compiling all customizations and comes with standard documentation and examples:
Note that also all ODS Wrapper based customizations and pages launched in Microsoft Internet Explorer will be changed to 64 bit. This means that extensive testing should be done before deploying in production.
