| Area: | Annotation |
In AECOsim Building Designer V8i, one could edit a Tag by just double clicking on the Text Tag and editing it as per requirement. But in CONNECT Edition, no Tag tools can be found. So one needs to use the Edit Item option to perform editing on Text Tag (as known in V8i series)
