| Version(s): | CONNECT Edition, V8i | ||
| Area: | Floor Management | ||
| Subarea: | N\A |
Whenever the file is closed the selected floor reverts back to 'none'
1. Open the file
2. Select the desired floor you want to set as default from the Floor Selector
3. Go to the backstage options by clicking on "File"
4. Click on "Save Settings"
The floor you choose will be automatically selected every time you open that file.
Please see this video for the workflow:
