Product(s): | OpenBuildings Designer (and AECOsim Building Designer) | ||
Version(s): | CONNECT Edition and V8i | ||
Environment: | N/A | ||
Area: | DataGroup System | ||
Subarea: | DataGroup Catalog Tools |
How can I copy the properties from a previously placed element to the placement/modify dialog?
Use "Match Element Properties", This tool sets the current active placement/modify dialog settings to match the parameters of an existing, selected catalog item instance in the model. This saves a good amount of time when placing catalog items that need to identically match those that already exist.
Note: The existing catalog item instance must be of the same catalog type selected with the Catalog Item Selector for the parameters to be matched.
Please see this video for a sample workflow,
