| Product(s): | OpenBuildings Designer (and AECOsim Building Designer) | ||
| Version(s): | CONNECT Edition and V8i | ||
| Area: | DataGroup System | ||
| Subarea: | DataGroup Validation |
21 Definition files referenced by Catalog Types were not found.
User tried creating a new WorkSet without selecting a valid template linked to an AECOsim dataset. That results in the creation of a Microstation WorkSet not an AECOsim WorkSet, and this WorkSet does not have the configuration variables with files required for AECOsim.
Create a new WorkSet with selecting an appropriate AECOsim template. Check Create a new Workset.
