Errors/Logs/Message dialogs/Crashes
While working on modelling software, it is quite natural that some errors, crashes, warning messages may generates. Modeler may expect different scenario to deal with all type of conditions, be it will be working pattern/behavior, certain investigation or customization which results to some ambiguous results, error, crashes etc. We will be discussing here some of the relevant or common errors which can be fixed, to discuss, and to be taken care of, and most important to avoid such scenarios.
Based on situation and feedback received, we will keep posting all possible cases.
communities.bentley.com/.../autoplant-modeler-connect-edition
