| Area: | Workspace | ||
| Subarea: | Configuration |
This list is no longer maintained but has been retained for reference during V8i to CONNECT Edition migration, it includes Power Platform configuration variable changes made at the initial release of MicroStation CONNECT Edition.
'New' Configuration Variables
New Configuration Variables |
Description |
_BUNDLE_DEPLOYMENTIMAGE_GUID |
_RIBBON_INITIAL_WORKFLOW |
_USTN_BUNDLE_UPGRADE_GUID |
_USTN_CONFIGURATION |
Root directory containing all configuration files. |
_USTN_DGNLIBLIST_SYSTEM |
_USTN_EXAMPLEWORKSETNAME |
_USTN_EXAMPLEWORKSPACENAME |
_USTN_FEATURETRACKING_DATASOURCE |
_USTN_GUIROOT |
_USTN_HAVEWORKSET |
_USTN_INSTALLED_CONFIGURATION |
_USTN_LOCALE_COUNTRY |
_USTN_LOCALE_LANGUAGE |
_USTN_ORGANIZATION |
Directory containing Organization configuration files. |
_USTN_PRIMARY_RIBBONRSCLIST |
System level variable that specifies the ribbon resource file(s) that are required. |
_USTN_WORKSETCFG |
Name of WorkSet configuration file. |
_USTN_WORKSETDGNS |
Search Path for design files. |
_USTN_WORKSETDGNWS |
Variable to identify full path of WorkSet’s DGNWS file. |
_USTN_WORKSETDGNWSTEMPLATE |
Variable to identify WorkSet DGNWS template File. |
_USTN_WORKSETNAME |
Application base WorkSet name. |
_USTN_WORKSETROOT |
Directory containing WorkSet-specific data. |
_USTN_WORKSETSDGNWSROOT |
Root Directory containing DGNWS files. |
_USTN_WORKSETSROOT |
Directory containing CFG and DGNWS files of all WorkSets of a WorkSpace. |
_USTN_WORKSETSTANDARDS |
Search Path for WorkSet Standards. |
_USTN_WORKSETSTANDARDSUBDIRS |
List of subdirectories automatically created for a new WorkSet's Standards. Separate the names by semicolon. |
_USTN_WORKSETTEMPLATE |
Variable to identify WorkSet template. |
_USTN_WORKSPACECFG |
The Configuration File that corresponds to one particular WorkSpace |
_USTN_WORKSPACENAME |
Specifies name of the WorkSpace. |
_USTN_WORKSPACEROOT |
Directory containing WorkSpace-specific data. |
_USTN_WORKSPACESROOT |
Directory containing CFG files of all WorkSpaces. |
_USTN_WORKSPACESTANDARDS |
Default locations for WorkSpace Standards. |
_USTN_WORKSPACESTANDARDSUBDIRS |
List of subdirectories automatically created for a new WorkSpace's Standards. Separate the names by semicolon. |
_USTN_WORKSPACETEMPLATE |
Variable to identify WorkSpace template. |
_VERSION_10_0 |
BMECH_VBA_LOADING_OPTION |
Mechanical VBA project startup options. |
MS_3DATTACHMENTS_DONOTCACHE |
MS_BUTTONMENUSEED |
File containing default button assignments. This file is used to define button assignments if the file defined by MS_BUTTONMENU is not found. |
MS_DGNLIBLIST_CLASH |
List of DGN library files that are used to find Clash Detection Interference Jobs and Reports for your current session. |
MS_DGNLIBLIST_LEVELS |
List of DGN library files that are used to define Level definition for your current session. |
MS_DGNLIBLIST_LINKS |
List of DGN library files that are used to find Link Sets for your current session. |
MS_DGNLIBLIST_PRINTING |
List of DGN library files that are used to find Print Styles for your current session. |
MS_DGNLIBLIST_RENDER |
st of DGN library files that are used to find Rendering Setups, Materials, and Lights, for your current session. |
MS_DGNLIBLIST_SCREENMENU |
List of DGN library files that are used to define the available Screen Menus for your current session. |
MS_DGNTEXTEDITORFAVORITESYMBOLS |
MS_DGNTEXTEDITORPREF |
MS_DWG_VPFREEZE |
MS_EXPLORER_SETTINGS |
Explorer user settings file. |
MS_EXPLORERSETTINGSSEED |
MS_FKEYMNUSEED |
File containing default function key assignments. This file is used to define function key assignments if the file defined by MS_FKEYMNU is not found. |
MS_GROUPPOPUPFADEKEYTIPS |
nitially show then fade the Ribbon Group Popup KeyTips. Press the Alt key to show the Group Popup KeyTips again. |
MS_GROUPPOPUPFALLBACKWORKFLOW_2D |
Workflow to use when the pop-up group path starts with a '*' and the active Workflow does not contain the specified group and the active model is 2D. |
MS_GROUPPOPUPFALLBACKWORKFLOW_3D |
Workflow to use when the pop-up group path starts with a '*' and the active Workflow does not contain the specified group and the active model is treated as 3D. |
MS_HIDETASKNAVIGATIONWORKFLOW |
If defined, hides Task Navigation in the ribbon bar Workflow Selector. |
MS_INPUT_CONFIGXML |
Overrides the default touch gesture configuration. |
MS_INPUT_CONFIGXMLSEED |
File containing default touch gesture assignments. This file is used to define touch gesture assignments if the file defined by MS_INPUT_CONFIGXML is not found. |
MS_INSTALLED_CULTURE |
MS_KEEP_ORIGINAL_ATTRIBUTE |
MS_KEYBOARDSHORTCUTS |
File containing user keyboard shortcuts. |
MS_KEYBOARDSHORTCUTSEXPAND |
If set to 1, the parent nodes will be expanded when the Keyboard Shortcuts dialog is opened. A value of 0 is the default. |
MS_KEYBOARDSHORTCUTSSEED |
File containing default keyboard shortcuts. This file is used to define keyboard shortcuts if the file defined by MS_KEYBOARDSHORTCUTS is not found. |
MS_KEYBOARDSHORTCUTSUSERORDER |
If set to 1, the order of the Keyboard Shortcuts in the menu will be the order set by the user. A value of 1 is the default. |
MS_LEGACYTOOLMAPLIST |
Defines list of Tool Map XML files that specify mapping of tools from 8.11 to Current version. |
MS_LEVEL_SYNCH_BYLEVEL |
If set, the active color, weight, and style are set to ByLevel when the active level is changed or a new model or view group is opened. |
MS_MACRONEWFILEDIRECTORY |
Default path to save new macros. This should be a single directory. |
MS_MDLSTUB_LOAD |
List of MDL Applications that will be stub-loaded, which means their resources are loaded but the code portion of the application is not yet loaded. |
MS_MESH_EXTRACT_BOUDARIES_MULTIPLE |
MS_PERSONALDGNLIB |
Personal DGNLIB files used to store user customizations. |
MS_PERSONALDGNLIBSEED |
Default seed file for creating personal dgnlib. |
MS_POINTCLOUD_LAS_NBIT_COLOR |
If defined and set to 8; will treat color as 8 bits. If set to 16; will treat color as 16 bits |
MS_POSITIONMAPPING_CONFIGURATION |
If undefined or set to any other value; will try to auto detect number of bit per color channel. |
MS_PUBLISH_EXTENSIONSASSEMBLIES |
MS_PUBLISHDGN_CLEAROVERLAYS |
MS_PUBLISHDGN_EMBEDFONTS |
MS_PUBLISHDGN_ENFORCE_VALIDATION |
MS_PUBLISHDGN_REMOVE_MISSING_ATTACHMENTS |
MS_PUBLISHDGN_REMOVE_MISSING_LIBRARY_ECXATTRIBUTES |
MS_REF_ENABLE_LEGACY_VISEDGE |
When set to 1, The use of the "Legacy" option for the reference Visible Edge option is enabled. The "Cached" option replaces the "Legacy" (True Hidden Line) option and provides superior performance and accuracy. |
MS_REF_NO_CVE_LOAD |
If this variable is set then any reference file with a CVE cache will not be loaded. This effectively overrides each CVE reference to use the "Cache Synch: Never (Disconnected)" option. Setting MS_REF_NO_CVE_LOAD can reduce the time to open large data sets, however, element properties are not available and certain annotation tools may be available for the unloaded/disconnected CVE references. |
MS_REPORT_OUTPUT |
Output directory for exporting report results |
MS_RIBBON_MAXBUTTONLABELCHARS |
Maximum number of characters to display for a ribbon button label. The default value is 24 if not set. The minimum value is 20. The maximum value is 128. |
MS_RIBBON_NUMEXPANDEDTASKGROUPS |
Once this limit is hit then all other tasks are placed in an Overflow group. |
MS_RIBBONCOMPONENTPROVIDERS |
List of AddIns containing ribbon components. |
MS_RIBBONDIR |
Base path where ribbon definitions are located. |
MS_RIBBONPREFS |
File name of file containing the current state of the Ribbon, like the active Workflow, active Tab, and setting for Ribbon Search. |
MS_RIBBONPREFSSEED |
File name of file use as a seed is the file specified by MS_RIBBONPREFS does not exist. |
MS_RIBBONRSCLIST |
List of RSC files containing application specific ribbon components. |
MS_RIBBONXML |
List of XML files containing ribbon components definitions, references and layout. |
MS_SCREENMENU_ANTIALIAS |
MS_TABLE_INPUT |
Directory containing Excel workbooks and CSV files to be used as data sources for tables |
MS_TASKNAVIGATION_CONFIGURATION |
MS_TOOLSETTINGSIGNORETITLEFORWIDTH |
When determining the width of the Tool Settings dialog, the width of the title is ignored. |
MS_UPDATE_KEEP_UNUSED_LIBRARY_LEVELS |
Controls if unused library levels will be kept or deleted on a "dgnlib update levels" command. If is not set or set to "0" then unused library levels will be deleted on executing a "dgnlib update levels" command. If set to "1" then unused library levels will be kept. If set to "2" then unused library levels will be deleted if their attributes are the same. |
MS_VIEWTOOLBOX2D |
Overrides for the View window toolboxes for 2D. The value can be the title of a system toolbox or user-defined toolbox. |
MS_VIEWTOOLBOX3D |
Overrides for the View window toolboxes for 3D. The value can be the title of a system toolbox or user-defined toolbox. |
MS_XCOMMAND_APPS |
List of MDL Applications that will have their XCommand tables auto-loaded. The applications are stub-loaded, which means their resources are loaded but the code portion of the application is not yet loaded. |
QV_DISABLE_D3D11 |
Setting QV_DISABLE_D3D11 to 1 forces the system to use Direct3D 9 (D3D9) rather than Direct3D 11 (D3D11). Since D3D9 is simpler than D3D11, some graphics hardware or drivers work correctly with D3D9 but not with D3D11. However, D3D11 is faster and preferable. Try upgrading to the latest driver for your hardware before setting QV_DISABLE_D3D11. |
QV_DISABLE_HARDWARE |
Setting QV_DISABLE_HARDWARE to 1 disables all hardware acceleration. This setting can be used to circumvent problems with graphics hardware or drivers, but it causes a large performance penalty. |
