| Area: | Workspace | ||
| Subarea: | Configuration |
This list is no longer maintained but has been retained for reference during V8i to CONNECT Edition migration, it includes Power Platform configuration variable changes made at the initial release of MicroStation CONNECT Edition.
'Deprecated' Configuration Variables
Deprecated Configuration Variables |
Description |
_LUMENRT_SHARED_CONTENT_PROGDATA_VISTA |
_LUMENRT_SHARED_CONTENT_PROGDATA_XP |
_MSCONFIG_CFG_ |
_PRODUCT_LOCALUSERTEMPPATH |
_USTN_ALTCHARTRAN |
_USTN_CONNECT_PROJECTGUID |
_USTN_DEFAULTUSER_CFG_FILE |
_USTN_DOCUMENTATIONROOT |
_USTN_FEATUREASPECTSDLLLIST |
_USTN_HELPTAG_* |
_USTN_INSTALLED_WORKSPACEROOT |
_USTN_OPEN3D_RIGHTISO_OFF |
_USTN_PROJECT |
Directory containing project configuration files. |
_USTN_PROJECTAPPNEW |
_USTN_PROJECTCFG |
Name of project configuration file. |
_USTN_PROJECTDATA |
Directory containing project-specific data. |
_USTN_PROJECTDESCR |
Description of current project configuration. (_USTN_PROJECTDESCR) |
_USTN_PROJECTNAME |
MicroStation base project name. |
_USTN_PROJECTSROOT |
Directory containing project-specific sub-directories. |
_USTN_PROJECTSUBDIRS |
List of subdirectories automatically created for a new project. |
_USTN_SHARED_CONTENT_PROGDATA_VISTA |
_USTN_SHARED_CONTENT_PROGDATA_XP |
_USTN_SITE |
Directory containing MicroStation site configuration files. |
_USTN_WORKSPACEROOT |
Root directory containing all workspace files. |
_VERSION_8_11 |
MS_ACCUDRAWKEYS |
Text file listing AccuDraw shortcut keys. |
MS_APP |
MS_ARCHIVE |
Search path(s) for Archive Files. |
MS_ARCHIVECLASS |
Search path(s) for Archive Class Files |
MS_AUTORESTORESTATUSBAR |
If set to 1, the status bar will restore its default appearance whenever the mouse enters it. |
MS_BASICEXT_LOAD |
List of MDL applications that implement extensions to the BASIC language |
MS_BATCHPLT_SPECS |
MS_CLRUICULTURE |
MS_CMDWINDRSC |
Application command window resource file. If not defined, use default |
MS_CODESET |
MDL application for handling multi-byte character sets. |
MS_DEFCHARTRAN |
Default character translation table. |
MS_DETAILINGSYMBOLS_CELLLIST |
defines the list of cell libraries to be searched for cells used as callout heads in detailing symbols. By default cells in ustation.dgnlib are used. |
MS_DISABLE_FILE_THUMBNAIL |
When turned on, this configuration variable will disable the file preview thumbnail images in the File Open dialogs. |
MS_DISPLAYSTYLE_LIBLIST |
Filters which DGN libraries (defined by MS_DGNLIBLIST) are searched when looking for display styles. Leave this undefined to search all of them (default). |
MS_DISTRIBUTED_DGN_AUTO_FOCUS_ON_NEW_CONFLICTS |
specifies whether the Conflicts dialog opens when the Refresh Local Copy command detects a new conflict. The default is on. |
MS_DISTRIBUTED_DGN_COMMIT_ON_CLOSE |
specifies whether changes are committed to the distributed DGN before the file is closed. |
MS_DISTRIBUTED_DGN_COMMIT_ON_SAVE |
specifies whether changes are committed to the distributed DGN when the file is saved. |
MS_DISTRIBUTED_DGN_CONFLICT_BY |
specifies how conflicts should be detected. MODEL detects conflicts within the same model. GG detects conflicts involving the same graphic group. Default is MODEL. |
MS_DRAWINGSEED_LIBLIST |
Specifies the set of files in which to search for drawing seeds. If not defined, all DGN library files are included. |
MS_DWG_LEVELDISP_FOR_VPORTFREEZE |
saves the level display status per view to viewport layer thaw/freeze status. Valid values are ON or no value or OFF. |
MS_ECTREE_LIBRARIES |
List of DGN files in which to find ECTree definitions. |
MS_ELEMENTEXPLORER_ENABLERS |
MS_GUIHAND |
MS_IFCREVIT2012SLABFIX |
MS_IMMEDIATEUPDATE |
MS_LEVELS_EXCLUDELIBS |
Specifies a set of library files to exclude from supplying levels to the user interface. This filter should specify a subset of files specified by MS_DGNLIBLIST and _USTN_SYSTEMDGNLIBLIST. |
MS_LIBRARY_SAVEDVIEW_FILTER |
MS_LOCAL_MATERIALS |
MS_MAINMENUDOCKINGBESIDE |
MS_MTBL |
MS_PLNONAME |
MS_PLTDLG_SETUPSYSPRT_ENABLE_PRINT |
MS_PTDIR |
MS_REALDWG_APPS |
MS_REF_REATTACH_LEVEL_SYNC_ATTRIBUTE_LIST |
MS_REFAGENTDATA |
MS_RSSMANIFESTSEED |
MS_SAVEDVIEW_EXCLUDELIBS |
Specifies a set of library files to exclude from the saved views user interface. The filter should point to only those files that are specified in MS_DGNLIBLIST and _USTN_SYSTEMDGNLIBLIST. If not defined, all library files are included. |
MS_SETMGR_CREATELEVELS |
MS_SETTINGS |
Current settings resource file. |
MS_SHARED_DR_DIR |
Working directory for shared rendering files, including Particle Tracing and Radiosity files. |
MS_SHAREDCONTENTDIR |
MS_SKETCHUP_IMAGE |
MS_SPELLINGLANGUAGE |
Specifies the language |
MS_SYMBOLPROVIDER_APPS |
MS_SYSFONTDIR |
MS_TASKDIALOGPREF |
MS_TASKMAPFILES |
MS_USECOMMANDWINDOW |
If set to 0, The application will be locked in the status bar interface. If set to 1, the application will be locked in the command window interface. |
MS_USECUSTOMSHEETSIZEDEF |
If set to 0, the sheet sizes will be derived from the active plotter driver. If set to 1, the sheet sizes in the Sheet Size definition file (MS_CUSTOMSHEETSIZEDEF) will be available for creating sheet models. If set to 2, the sheet sizes from both sources will be used for creating sheet models |
MS_VECTORICONDATADIR |
Defines the directory containing the file VectorIcon.dgnlib. This variable can be used when attaching the lighting model, stored in VectorIcon.dgnlib, as a reference attachment. |
MS_VECTORICONOUTPUTDIR |
Defines the directory where ico files are generated when the user selects the 'Generate ico file in Selected Directory' option on the 'Generate Icon' dialog. |
MS_VECTORICONSETTINGS |
MS_VECTORICONSETUPDGN |
Defines the file that contains the Vector Icon seed model named 'Icon' and the Vector Icon seed saved view named 'Icon Render'. This variable should specify the fullpath to the delivered VectorIcon.dgnlib file. |
MS_XATTRIBUTE_HANDLER_LOAD |
PUBLISHDGN_ECPROPERTIES_NOT_TO_FILTER |
PUBLISHDGN_REMOVEATTRIBUTEIDS |
QV_D3DVERSION |
