| Area: | Workspace | ||
| Subarea: | Configuration |
Following the changes configuration in structure the CONNECT Edition introduces several new configuration variables, and either supersedes and deprecates others.
Lists of configuration variables can be found in help documentation by searching for 'configuration variables'.
The MicroStation Platform team maintain pages listing configuration variables at MicroStation CONNECT Edition Configuration Variables
For reference during V8i to CONNECT Edition migration we have the following non-maintained lists of Power Platform configuration variable changes made at the initial release of MicroStation CONNECT Edition.
