| Area: | Workspace | ||
| Subarea: | Configuration |
This list is no longer maintained but has been retained for reference during V8i to CONNECT Edition migration, it includes Power Platform configuration variable changes made at the initial release of OpenBuildings Designer are listed below. If these variables are set in an existing V8i custom WorkSpace their equivalents should be substituted when migrating CFG files to OpenBuildings Designer.
Configuration Variable Name |
Description |
CONNECT Edition Equivalent |
_BB_DATASET_COMPANY_DG_LOCK |
Specifies the location of the Primary, Organization, shared or centralized dataset filtering settings |
_BB_DATASET_ORGANIZATION_DG_LOCK |
ATFDIR_CELL |
Location of Architectural application cell libraries |
TFDIR_CELL |
ATFDIR_DATA |
Location of Architectural application data files |
TFDIR_DATA |
ATFDIR_HELP |
Location of Architectural application help file |
MS_HELPPATH |
ATFDIR_MDLAPPS |
Location of Architectural application MDL applications |
TFDIR_MDLAPPS |
ATFDIR_PREFS |
Location of Architectural application preference file atfprefs.rsc |
TFDIR_PREFS |
ATFDIR_SETTING |
Location of Architectural application settings files |
TFDIR_SETTING |
ATFDIR_VBA |
Location of Architectural application Visual Basic for Applications (VBA) files |
TFDIR_VBA |
ATFDIR_XLS |
Location of Architectural application Excel seed files used when Excel is chosen to format reports for the Quantify and Schedules tools |
TFDIR_XLS |
BB_DATASET_COMPANY_FILTER |
Location of the shared or centralized dataset, to be used in destination filtering in the DataGroup System |
BB_DATASET_ORGANIZATION_FILTER |
BB_DATASET_PROJECT_FILTER |
Location of the Project (now Workset) Dataset, to be used in destination filtering in the DataGroup System |
BB_DATASET_WORKSET_FILTER |
BB_DGNLIBLIST_LINKS |
List of DGN library files that are used to find Sheet Indexes and Link Sets for your current session |
MS_DGNLIBLIST_LINKS |
BB_LEVEL_DGNLIBLIST |
Locations and names of DGNLIB files which are used to define the Level Libraries for your current session |
MS_DGNLIBLIST_LEVELS |
BB_RFA_COMPANY_SETTINGS |
Specifies the location of the RFA wizard setting for the Company (now Organization) Dataset |
BB_RFA_ORGANIZATION_SETTINGS |
BB_RFA_PROJECT_SETTINGS |
Specifies the location of the RFA wizard setting for the Project (now Workset) Dataset |
BB_RFA_WORKSET_SETTINGS |
HVAC_DATASET |
Location where the Mechanical application dataset folders are stored |
TFDIR |
HVAC_DATASETNAME |
Specifies the active Mechanical application dataset |
TF_DATASETNAME |
HVACDIR_ASSEMBLIES |
Location for Mechanical application assemblies |
TFDIR_ASSEMBLIES |
HVACDIR_DATA |
Location for some of the Mechanical application interface customization files |
TFDIR_DATA |
HVACDIR_HELP |
Location of the Mechanical application help file |
MS_HELPPATH |
HVACDIR_MDLAPPS |
Location for various MDL applications associated with Mechanical application |
TFDIR_MDLAPPS |
HVACDIR_PREFS |
Location of the Mechanical application preference file |
TFDIR_PREFS |
HVACDIR_VBA |
Location for the Visual Basic mvba files used to generate Mechanical components |
TFDIR_VBA |
IFC_SETTING |
Location for IFC setting files, such as export filters, and mapping files |
IFCDIR_SETTING |
IFC_PROJECT_SETTING |
Location for workset-specific IFC setting files, such as export filters, mapping files, etc. |
IFC_WORKSET_SETTING |
STF_DATASET |
Location where the Structural application dataset folders are stored |
TFDIR |
STF_DATASETNAME |
Specifies the active Structural application dataset |
TF_DATASETNAME |
STFDIR_ASSEMBLIES |
Location for Structural application assemblies |
TFDIR_ASSEMBLIES |
STFDIR_DATA |
Location for some of the Structural application interface customization files |
TFDIR_DATA |
STFDIR_HELP |
Location of the Structural application help file |
MS_HELPPATH |
STFDIR_MDLAPPS |
Location for various MDL applications associated with Structural application |
TFDIR_MDLAPPS |
STFDIR_PREFS |
Location of the Structural application preference file |
TFDIR_PREFS |
STFDIR_SETTINGS |
Location for Structural settings files. Contains settings files for Automated Structural Drawings, joist girders, model coping (auto coping), and quantification |
TFDIR_SETTING |
TFDIR_HELP |
Location of the AECOsim Building Designer help file |
MS_HELPPATH |
