| Area: | Workspace | ||
| Subarea: | Configuration |
This list is currently not maintained but has been retained for reference during V8i to CONNECT Edition migration, it includes Power Platform configuration variable changes made at the initial release of AECOsim/OpenBuildings Designer CONNECT Edition. (we intend to update it with new variables added since the initial release)
New Configuration Variables
Configuration Variable Name |
Description |
IFCDIR_PSD4 |
Specifies the directory paths where IFC2x3 Property Set Definition files are stored. (IFCDIR_PSD4) |
BMECH_PIPE_TURNDOWN_SIZE |
Specifies Set the pipe turndown mode to fixed with the specified size. Value must be in MU:SU format. (BMECH_PIPE_TURNDOWN_SIZE) |
BB_DVDATASETELEMENTDISABLE |
If set to 0 or undefined (default), specifies that certain dataset linestyles, patterns and levels will be added to the file if necessary to support Dynamic Views. If set to 1, no such elements are added, resulting in degraded Dynamic View display. |
BB_DVLEVELSDISABLE |
If set to 0 or undefined (default), specifies that certain dataset levels will be added to the file if necessary to support Dynamic Views; in addition, these levels' DV usage is tracked. If set to 1, DV Levels are neither created nor tracked, resulting in degraded Dynamic View display. |
