How to Perform Automatic Cable Routing in Bentley Raceway & Cable Management-CE
Product(s):Bentley Raceway & Cable Management
 Version(s):CONEECT Edition (10.04.00.31)
 Environment:N/A
 Area:Cable Routing
 Subarea:N/A
In Bentley Raceway & Cable Management, Cable Routing settings that controls the automatic selection of nearby raceway routes can be adjusted. A bounding sphere, at the equipment, is used by the automatic cable routing function to determine possible cable routes. When a raceway route intersects any part of a bounding sphere, those routes are a valid cable routing path to the equipment. Therefore, a raceway route does not necessarily need to connect directly to the equipment for the path to be consider as a valid cable routing path.
Steps To Accomplish
  1. Launch Bentley Raceway & Cable Management CONNECT Edition.
    Select WorkSpace and WorkSet and open ROUTING.dgn.
  2. Click Cable Manager tool in Equipment & Cable ribbon tab, Cables ribbon group.
  3. From Cable Manager, Select Manage and then Collaboration Manager.
  4. In Collaboration Manager, right click, then Select All and Request lock.
  5. Cables are now loaded in Cable Manager.
  6. In Cable Manager, Right Click, Select all, and select Auto Connect.
    Note: The Auto Connect function will create this connection and populate the length field with the shortest orthogonal length between source and destination equipment.
  7. In Cable Manager, Right Click, then select Routing Manager.
  8. Cables are now loaded into Routing Manager.
  9. Right click, then Select all the cables to be routed and select Automatic Routing.
  10. As it is evident from the example, that all the Cable Routes except the two got successful.
    Press OK and proceed.
  11. From Routing Manager, it is easy to find the reason of Automatic Routing failure from Info.
    Press Ok and Proceed.
  12. Save the changes.
  13. From Cable Manager, it is evident that the Routing Mode is Automatic Routing.
See Video
www.youtube.com/watch
