| Product(s): | OpenBuildings Energy Simulator | ||
| Area: | Building Modelling | ||
| Subarea: | N/A |
Should architects plans change, then the background DGN / DWG / DXF in your OpenBuildings Energy Simulation project can be changed without having to delete any rooms modelled.
To change your plan drawing go to the project tree and right-click on the floor in question, and select properties:
Navigate to the new Drawing by clicking on the button below:
