| Product(s): | OpenPlant Isometrics Manager CONNECT Edition |
| Version(s): | 08.11.XX.XXX |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | General |
| Subarea: | Installation/Upgrade |
| Original Author: | Abhijeet Shinde, Bentley Product Advantage Group |
Deployment Image-
The deployment image is created by the system administrators for installing the application with the same installation configuration includes the installation location, features, shortcuts, additional packages, and so on.
Once created, user will be able to double- click Setup.exe for the software available in the deployment image to install the application with the set configuration without the need of any user interaction or internet connection for component downloads. The deployment image can be shared in the network.
The deployment image contains all the files that are packaged with the product as well as the downloadable files, including companion features and applications. It may optionally contain external applications or packages that you add while creating the deployment image which may be pre-requisites for the software. The image does not analyze the system on which it is created. It simply saves all the components for installation. The deployment image also saves the installation configuration.
1.In the command line type in Run to open Run Command
2.Click on Browse folder and go to the location of the setup file for OPIM CONNECT.
3.Select the setup file of OPIM CONNECT and click on Open
4.Path of the setup file is added in the Run dialog box and add /layout after .exe in the open dialog box and click ok.
5.The OPIM CONNECT dialog opens. Go to ‘Configure’ tab.
6.Select the installation location where the deployment image will get installed. Click on Next.
7.Select ‘Delivered Configuration’ option and then select the location of delivered configuration to be installed. Click Next
8.Select ‘Passive UI Mode’, and then select the deployment image location according to requirement and select ‘Next’
9.Select the features and Click on Done
10.Click on Layout which will start creating the layout of the deployment image and download all the required files
11.After completion of the download the deployment image will be created at the selected location.
Run the Setup file to install the OPIM CONNECT software.
communities.bentley.com/.../installation---autoplant-modeler-connect-edition
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
