Area:User Interface
| Subarea: | N/A |
Click on the File - Settings command button while in a drawing to access the Backstage area where you will find things like Configuration Variables and File - User command button to find Preferences. Tip: To quickly return from Backstage view to your view window, press <Esc>.
