| Area: | User Interface | ||
| Subarea: | N\A |
Has the "Delete Opening Tool" from AECOsim Building Designer SELECTSeries6 been removed from CONNECT Edition? When an opening is created onto a form with a shape, how can I delete it?
This tool is now named "Delete Building Features", and is available from the Delete tool drop-down in the AECOsim workflow's Common Tools > Selection tool group:
In addition, you can also right-click on the element and select Building Element Info > Features. Select the opening and delete it from the Building Element Info dialog box.
