| Product(s): | OpenPlant Modeler, OpenPlant PID, OpenPlant Isometrics Manager, OpenPlant Support Engineering, OpenPlant Orthographics Manager, OpenPlant Project Administrator |
| Version(s): | CONNECT Edition & v8i |
| Environment: | - |
| Area: | Products, Services, General |
| Subarea: | - |
| Original Author: | Bentley Product Advantage Group |
In these challenging times when COVID-19 is imposing significant disruptions to day to day activities and affecting normal business flow of our much-valued users and employees, we at Bentley are mindfully committed to ensuring smooth transition of work from office to remote location or home. Our innovative software and services are all geared for working from home or remote locations and do not impose the need to be in an office set-up.
To ensure smooth transition of work and effectiveness of your daily workflows with Bentley software, we have assembled information that you can refer to while working remotely or from home. We are working hard to deliver high levels of customer service, and welcome feedback, questions, and ideas on how we can serve you better in a remote work environment.
You may decide to install the software on your home computer. If you do this, once signed in via the CONNECTION Client using your normal work email login, you will have the same licenses available as you do in the office
There are several options to work remotely. You may decide to install the software on our home computer. See these minimum machine requirements for OpenPlant Modeler, OpenPlant PID, OpenPlant Isometrics Manager, OpenPlant Support Engineering, OpenPlant Orthographics Manager and OpenPlant Project Administrator
Processor |
Intel® or AMD® processor 1.0 GHz or greater. OpenPlant products are not supported on a CPU that does not support SSE2. |
Memory |
16 GB minimum, 32 GB recommended. More memory almost always improves performance, particularly when working with larger models. |
Hard Disk |
24 GB free disk space (which includes the 16 GB install footprint for a complete installation), 10-25 GB depending on additional installations such as Companion Features and Companion Products. |
Video |
See the graphics card manufacturer for latest information on DirectX drivers. 512 MB of video RAM or higher |
Screen Resolution |
1024 x 768 or higher |
Internet access is required for downloading and installing the software. The OpenPlant Modeler installer is almost 1.6 GB and all OpenPlant products are almost 8 GB, therefore we recommend adequate data and bandwidth. After downloading the small installer setup file, if you are facing problems running it for downloading the full software, you can download the full software installer directly from the link shared below in DOWNLOADING SOFTWARE section.
OpenPlant products will try to obtain your Internet Proxy Settings from Internet Explorer browser. If it is not feasible, you can fill the details manually as described in this MicroStation blog page.
Virtual Private Network enables organizations to provide secure connection to their network over Internet so their employees can connect remotely or from public places. Follow these instructions to connect to Windows VPN. If your organization uses a different VPN software, contact your IT Administrator to guide you with the steps.
The following features of OpenPlant products may not work properly in the absence of Internet connectivity.
Important notice about use of Bentley applications in virtual environments - click here
Virtualization enables organizations to create virtual machines from a single physical machine and administer them to their employees on demand.
OpenPlant products are certified on Citrix XenApp. Follow the steps given below to set it up.
Bentley is exploring other virtualization providers like VMWare Horizon and Azure Virtual Desktop. If your organization uses any of these, please reach out to us with your questions and we’ll try our best to assist.
Virtual Machines are a great way to manage operating systems and work remotely with a running Remote Desktop Connection, login credentials and a valid IP Address. Installing virtualization software allows one or more virtual machines to share one physical computer. Your IT Administrator can create VMs with a readymade image of Windows operating system that includes OpenPlant products and any other software needed. When such a VM is provisioned to you, you can directly launch OpenPlant products and start working on your project.
You can create a new VM and install its operating system by following these simple steps.
You can export and import existing VMs in Windows Hyper-V Server by following these steps.
If you work on a heavy-duty desktop machine that is difficult to carry or if your organization does not allow employees to move computers out of the office premises, Remote Desktop Connection offers a great way to log into that machine from your personal computer. You will require your computer name or IP address. Click here to follow the instructions in this page.
When you’re working remotely, you are still part of a team and therefore sharing of project data is crucial. This is where the Configuration system shines. No matter where you are, you can be sure to be using the correct CAD standard with server-based Configurations. If your system has already been configured to use server-based resources virtualization and remote desktop access results in a similar experience to
working in the office, there may be some graphic latency, but the system will be identical.
Attempting to connect to a configuration on office-based shares via VPN may be possible, depending on your IT systems, but is likely to be subject to significant latency, especially with many more VPN users than usual. Working with a local copy of the network configuration may be more appropriate.
Store your Project data on ProjectWise Share or Microsoft OneDrive that allows high level of control. Easily manage and transfer without the need for additional software.
The beauty of working with ProjectWise is that work sharing is built-in and the concept of being tied to a location is foreign. In a Client-Server architecture the client can be anywhere. By storing standards and work files on a server you can ensure proper access for anyone. By establishing a digital environment for all project information, you can give access to people regardless of location and device type. However, ensuring the correct access is the key to success.
So, setting up ProjectWise Explorer locally is key.
The way to install ProjectWise Explorer can be found here.
