Product(s): |
OpenBuildings Designer CONNECT Edition | |
Version(s): |
CONNECT Edition | |
Area: |
Platform Tools |
How to change and match different attributes in OpenBuildings Designer ?
For Example if you have two lines with different Line Styles. Levels and Line Weight, you can change and bring them under same attributes.
For that go to Common Tools Section
Then go to, Change Element Attributes
Then, as per your requirements, you can choose Level, Color , Style and etc. from the generated Change Attributes window and apply on respective lines.
To match any line element attributes, pick up the Primary elements which attributes you want to apply and then click on destination elements.
