IFC - Certain Elements Do Not Appear in COBie
Product(s):OpenBuildings Designer (and AECOsim Building Designer)
Version(s):CONNECT Edition and V8i
Area: Import/Export
Subarea: IFC
Problem Description
Why don't all of the elements in a design model export to IFC COBie
Steps to Resolve
COBie is a subset of IFC, i.e., only selected objects are extracted from the model and are included in the COBie spread sheet. The objects that are extracted are those defined by COBie as being Physical assests that will require maintenance or tracking, e.g, chairs, light fixtures, etc.
Walls, columns and slabs are not generally included in the export as they are deemed not to require maintenance.
As the (FMH) Facilities Management Handover/COBie Model View Definition (MVD) is focused on ‘manageable assets’, elements such as walls, columns, beams, slabs, stairs, etc. are excluded and not exported. The excluded IFC classes are defined in:
…/Dataset_<region>/setting/IFC_COBieFilter.set.
If you comment out classes, they will be exported, but that may violate the MVD. To comment add double-slash (//) in the front of the line. Do not forget to enable type object classes when you enable entity class.
Example file content from Dataset_ISO19650:
| IFC EXPORT FM Handover / COBie filter
| $RCSfile: IFC_COBieFilter.set,v $
| $Revision: 1.2 $
| $Copyright: (c) 2021 Bentley Systems, Incorporated. All rights reserved. $
VERSION 2.2
FILE_DESCRIPTION "ViewDefinition [FMHandOverView]";
EXCLUDE_DOMAIN
//OBJECT IDM IGNORED ENTITY LISTS
//Source: COBie TOOLKIT USER GUIDE
//Release: Beta 1.3
//Release date: April 18, 2013
IfcAnnotation
IfcBeam
//IfcBeamStandardCase
IfcBeamType
IfcBuildingElementPart
IfcBuildingElementProxy
IfcBuildingElementProxyType
//IfcCableCarrierSegment
IfcCableCarrierSegmentType
//IfcCableSegment
IfcCableSegmentType
IfcColumn
//IfcColumnStandardCase
IfcColumnType
IfcCovering
IfcCoveringType
IfcCurtainWall
IfcCurtainWallType
IfcDistributionPort
IfcDuctFittingType
//IfcDuctSegment
IfcDuctSegmentType
IfcElementAssembly
IfcFastener
IfcFastenerType
IfcFeatureElement
IfcFeatureElementAddition
IfcFeatureElementSubtraction
IfcFlowFitting
IfcFlowFittingType
IfcFlowSegment
IfcFlowSegmentType
IfcFooting
IfcJunctionBoxType
IfcMechanicalFastener
IfcMember
//IfcMemberStandardCase
IfcMemberType
IfcOpeningElement
//IfcOpeningStandardCase
IfcPile
IfcPipeFittingType
//IfcPipeSegment
IfcPipeSegmentType
IfcPlate
//IfcPlateStandardCase
IfcPlateType
IfcProjectionElement
IfcRailing
IfcRailingType
IfcRamp
IfcRampFlight
IfcRampFlightType
//IfcRampType
IfcReinforcingBar
IfcReinforcingMesh
IfcRoof
IfcSlab
//IfcSlabElementedCase
//IfcSlabStandardCase
IfcSlabType
IfcSpaceType
IfcStair
IfcStairFlight
IfcStairFlightType
//IfcStairType
IfcStructuralAction
IfcStructuralActivity
IfcStructuralConnection
//IfcStructuralCurveAction
IfcStructuralCurveConnection
IfcStructuralCurveMember
IfcStructuralCurveMemberVarying
//IfcStructuralCurveReaction
IfcStructuralItem
IfcStructuralLinearAction
IfcStructuralMember
IfcStructuralPlanarAction
IfcStructuralPointAction
IfcStructuralPointConnection
IfcStructuralPointReaction
IfcStructuralReaction
//IfcStructuralSurfaceAction
IfcStructuralSurfaceConnection
IfcStructuralSurfaceMember
IfcStructuralSurfaceMemberVarying
//IfcStructuralSurfaceReaction
//IfcSurfaceFeature
IfcVirtualElement
//IfcVoidingFeature
IfcWall
//IfcWallElementedCase
IfcWallStandardCase
IfcWallType
ALLOW_PROPERTY_SET
Pset_*
ePset_*
COBie_*
@AirHandling
@AirDistribution
@Door
@Furniture
@ObjectManufacturer
@ObjectPostalAddress
@Plumbing
@Properties
@Pumps
@Space
@Spaces
@Specialty_Safety
@VAV
@Window
BaseQuantities
// Add further or remove property set names as required (without .xsd extension).
// Use wildcards (*) as necessary, e.g.
// Pset_* - export all property sets starting with 'Pset_' for all objects
// Door - only export the 'Door' property set, but not ArchDoor, Door_PAZ, etc.
// ObjectManufacturer FOR Casework - export the ObjectManufacturer property set only for Casework
// *COBie* - export every property set that includes the string 'COBie'
// @<property set> - export using the internal property set name, not the display name
SYSTEMS
"Properties/@SystemId"
PREFERRED_CLASSIFICATION Uniclass
// Enter the preferred classification system name
ONLY_ONE_CLASSIFICATION
