| Area: | Platform Tools | ||
| Subarea: |
Reality Mesh |
OpenBuildings Designer provides direct integration of the high-resolution 3D models created by the Bentley ContextCapture software. The Reality Mesh models (.3mx) can either be opened directly or attached as references to existing models. Integrating Reality Mesh photogrammetry technology has provided following benefits:
Below is the workflow that needs to be followed in order to insert Reality Meshes in a model:
Step 1> Click on the Attach tools icons and select the Reality Mesh option or from the drop-down (Drawing > Attach > Reality Mesh > Attach Mesh)
Step 2> Click on the Attach Reality Mesh icon and browse to your.3mx or .3sm file. Instead of browsing to a file, you can also directly enter the file's URL or you can use Key-in: MRMESH ATTACH
Step3> (Optional) Tick the "Attach and Apply Geographic Coordinate System" check box to align the Reality mesh with the 3D design Model.
