| Area: | Drawing Views | ||
| Subarea: | Markers |
How can I easily select a specific Marker/Clip Volume in a congested area where all of the Markers seem to overlap each other?
This can be accomplished by using the Show Saved View Boundary option:
1. Make sure that Constructions are enabled in View Attributes.
2. From the Ribbon Bar, select the Drawing Production tab and open the Saved Views dialog.
3. In the Saved Views dialog, click the Show column for the specific Saved View whose Boundary (Clip Volume) you would like to display.
4. Once enabled, that Boundary/Clip Volume may be selected anywhere along its visible geometry, not just at the Marker position.
