OpenPlant Isometrics Manager CONNECT Edition Interface Overview
Applies To OpenPlant Isometric Manager Connect Edition
Product(s):OpenPlant Isometric Manager CE
Version(s):
10.xx.xx.xx
Environment: Windows 7/8.1/10 (64-bit)
Area: Open/Save
Subarea: Open/Save
Original Author:Abhijit Bute,Bentley Product Advantage Group
OpenPlant Isometrics Manager CONNECT Edition interface has been change with respect to OpenPlant Isometrics Manager V8i.
This wiki article gives you introduction regarding new interface of OpenPlant Isometrics Manager CONNECT Edition, following details will give introduction of new interface & Tools which is normally use for modification of seed file or Generated Isometric.
Workflow
By default, 5 workflows available, user can use specific workflow as per task they want to perform, user can select specific workflow.
  1. Isometrics
  2. Drawing
  3. Modeling
  4. Visualization
  5. Task Navigation
For modification of existing isometric or seed file normally following workflows are use.
  Isometric
  Task Navigation
 Isometric Workflow interface
 Task Navigation Workflow interface
communities.bentley.com/.../how-to-use-custom-cell-as-user-labels-for-instrument-symbol
Still a Problem?
