| Product(s): | OpenBuildings Designer | |
| Version(s): | CONNECT | |
| Environment: | N\A | |
| Area: | Drawing Views | |
| Subarea: | Drawing Seeds | |
Problem Description
The Detailing Symbol Style in the Place Callout tools dialog is grayed out and cannot be changed to a custom detailing symbol style, or if changed it reverts to default.
Steps to Resolve
Go to your desired dataset location similar to this: C:\ProgramData\Bentley\Configuration\Datasets\Dataset_NM\DgnLib\
- Open DetailingSymbolStyles.dgnlib.
- Set the active View Group to Default.
- Search for Detailing Symbol Styles in search bar, and create your desired Detailing Symbol Style.
- Select your newly created style, right click and Activate.
- Choose File > Save Settings > Close.
- Open DrawingSeed_Architectural.dgnlib.
- Set the active View Group to your desired Views (Example: Arch-Floor Plan Views).
- Open the Saved Views dialog box.
- Select the saved view you have created and right click to Properties.
- In the General tab, select Detailing Symbol Style and change the value from Default to your selected custom detailing symbol.
- Select "Update Saved View Settings"
- Choose File > Save Settings.
- Open your model and you will see the change in the Detailing Symbol Style selection. It will still be grayed out, but will have the new custom symbol style selected.
